Signal 5%
  • gary229
    • 265
    Signal 5%
    Done loads of these boxes, provider is spot on as all other boxes are tip top
    The issue I have is sky sports 2 & 5 signal drops to 5%
    all +1 channels work fine, normal channels drop to 5%
    for example gold 5% gold +1 working fine.
    dropped aj's latest channel list, can't seem to find red button selection on favs which has thrown me a bit as all others have it.
    any help would be much appreciated
    Gary
    Try a different setting on your lnb mate
    • gary229
      • 265
      How do you go about doing that mate? I'm normally a dreambox user, but these boxes are cheap and easy to fire up.
      why would all these channels be working and those highlighted don't?
        Same here although now got a gigablue HD quad plus. had a problem with ssp1 not clearing on me dads openbox went into lnb settings messed around with them and found one that worked. look here hope it helps http://www.digital-kaos.co.uk/forums...ox-s10-229715/
        • gary229
          • 265
          Had a wee look at that post Maca, the dish being used is a communal one above flats, think the dish provides 8 flats.
          My young cousin has the same set up with a v8s, all channels working fine.
          • gary229
            • 265
            Are the lnb settings easy enough to find on the v5s or is it behind a hidden screen?
            • slugworth
              • Nov 2011
              • 1064
              maybe you are only getting 1/2 the transponders,like h only or v only.
              I would check the tp list to make sure you are getting all the transponders in the channel list.
              • gary229
                • 265
                Possibly Slugworth, though I would expect to have less channels if that was the case. Every fav group pretty much 100% ok.
                whats thrown me is, gold, sky1, Sky Atlantic, living etc are the only ones dropping in signal, the +1s are fine.
                sky sports 2 & 5 has really thrown me as Ive always thought if you got one you normally get them all unless a new channel list update was required.
                • Hadron
                  • 2102
                  SS2 & 5, plus gold, $ly1, $ly Atlantic are all on V transponders (All the +1 channels of gold, $ly1, & $ly atlantic are all on H transponders). Although $ly Living +1 is on an V transponder, so are you sure that you're receiving that one?
                  How about Dave (V) & Dave ja vu (H), or Lifetime (V), Drama (V) & $ly arts 1 (V)?
                  It looks like you may need the "no signal fix".
                  • gary229
                    • 265
                    Hadron, I'm thinking this may be the case. Problem is its a communal dish above 8 flats, bummer not the easiest to get to the lnb
                    • Hadron
                      • 2102
                      The "no signal fix" plugs into the skybox/openbox. No need to touch the LNB or dish.
                      • gary229
                        • 265
                        Hadron can you point me in the direction where to get one. Im a dreambox user, thought it was a fix at lnb end mate. Thanks bud
                        • gary229
                          • 265
                          Hadron, spotted these on ebay. As I said only problem is its on a communal sat, it says one end in at sat box and one at dish end mate. big problem
                            on a communal Sat system its more than likely using a Quattro LNB for the feed into the switch giving HH,HL.VH,VL frequency's. most of the Channels you have mentioned are on the Vertical High band which would suggest a problem with that band alone meaning the LNB or the Multiswitch is at fault.
                            Could also be a tuner problem in the Box itself, can you try another V5s to see if it results in the same behaviour
                            • Hadron
                              • 2102
                              You just need to unscrew the cable that goes into the LNB input of your box, & place the "no signal fix" in between.
                              So that you plug the cable from the LNB into the socket end of the "no signal fix", & the plug end of the "no signal fix" screws into the LNB connector on the box.
