SkyBox F5s Wifi
  • padge69
    • Feb 2014
    • 63
    SkyBox F5s Wifi
    Not sure if anyone has asked this so apologies if thay have and i have not seen it.
    Ive just got a new box so decided to put my F5s upstairs.
    I have the official SkyBox wi-fi dongle thing...
    However, it will not connect to $ channels and just says Scrambled.
    I have no idea if i have set this up right of not but when it asks me for my Router key, I enter the correct one be keep getting an error message telling me something along the lines of "invalid key, please input 5-13 digits" or something like that!
    My key is 10 digits long and is correct everytime im putting it in.
    Am I doing something wrong??
    Please help?
  • martin035
    • Apr 2014
    • 1308
    Could be something simple as capitals in your WiFi key, had this problem when I tried to connect my TV to the Internet.
    • padge69
      • Feb 2014
      • 63
      Tried that pal... Still nothing!
      • martin035
        • Apr 2014
        • 1308
        Can you turn the Encryption off on your router to see if it connects, to ensure that the box and wifi adaptor are working correctly and compatible?
        If that's OK then ensure both the router and box have the same Encryption protocols ie both on either WEP or WPA or WPA2
        Another thing you could try is turning your mobile phone into Portable Wifi Hotspot and see if your box can connect to that device.
        • padge69
          • Feb 2014
          • 63
          Is there a guide on setting this up anywhere mate?
          Want to make sure im doing it right
          • martin035
            • Apr 2014
            • 1308
            Whilst I was searching for a guide I found this on the forum, sounds very similar to your problem, the answer was to change the encryption method on your router.
            To do this you will have to access your router via a computer, google will be you friend for this, just search ''how do I access 'make and name of route'' normally it's via your web browser and the IP address of the router, good luck
            • dizzyandscoop
              • Feb 2014
              • 5
              Best of luck with this mate. I had a very similar issue tried router settings, no encryption and changing key for something simple. All this failed ended up going home plugs. Problem sorted. Not sure if the dongle just died. No one local I know to test with.
              • padge69
                • Feb 2014
                • 63
                Ill give this a try but not sure how to change the encryption tbh!
                I have a new Sky Hub so not entirely sure how to do this....... Suppose google will show me what to do!
                Cheers chaps
                • P&D
                  • May 2010
                  • 2686
                  If you don't know how to change the settings in the hub
                  go & buy these TP-LINK TL-PA411KIT AV500 500 Mbps Powerline Adapter Starter Kit Deals | Pcw
                  They are great you may get them cheaper elsewhere but they do the trick
                  • padge69
                    • Feb 2014
                    • 63
                    Sorted it.... All up and running
                    Thanks guys
