hi everyone
  • macumal
    • May 2014
    hi everyone
    iam about to try and install new updates.could need help.cheers alan
  • pgreenie1
    • Feb 2014
    • 41
    If you could give us some idea as to what you are updating and with what I'm sure you will find help
    • macumal
      • May 2014
      skybox f3. tried upgrading with usb on aj's list. when I press info after burn it says file not found
      • P&D
        • May 2010
        • 2686
        Hi have a look at this guide http://www.digital-kaos.co.uk/forums...9/#post1462805
        • macumal
          • May 2014
          hi and thanks
          where do I find an image file?
          • lee11168
            • Feb 2011
            • 217
            you change img file to misc then press upgrade
            • Hadron
              • Nov 2012
              • 2102
              The file has to have the correct name to be recognised as a channel list. If you download it from these forums, it will need to be uncompressed first, so it extracts as TP_PROG.dbs. If you download it straight from AJ's website, it doesn't need extracting.
              Copy TP_PROG.dbs file onto USB memory stick (FAT32).
              Insert USB memory stick.
              Press Menu button.
              Select "Delete all" from "Edit channel" menu.
              Select "Yes" to confirm.
              Select "Upgrade by USB" from "Tools" menu.
              Select "Misc. Files" from "Upgrade mode" option.
              Scroll to "Select & Upgrade" & press OK button.
              Select TP_PROG.dbs & press OK to place tick next to it.
              Press yellow button on remote to start upgrade.
              Wait for Burnflash to complete.
              Press "Info" button to verify TP_PROG.dbs has upgraded (should say OK).
              Press "Power" button on remote to put box into standby.
              Press "Power" button again to boot box.
              • DW190
                • May 2012
                • 1263
                I find a lot of people download the file when they have an old one still in their downloads folder thus giving the new download a different file name i.e.
                "TP_PROG(01).dbs which is not recognised (File Not Found) by the box.
                I always recommend to clear the download folder of any old files as well as the mem stick.
