V8s Freezes when connected to lnb
  • visiondvd
    • Apr 2012
    • 15
    Hi all
    I have two v8s and both, after installing ch list freeze when connected to lnb.
    If you disconnect lnb, menu works fine, but once lnb connects everything froze, menu and all.
    I have to disconnect cable and reboot box to get to menu.
    I have tried a couple of different firmware, and tried loading via usb and flashing.
    Tried older ch list, tried changing lnb settings etc.
    Any ideas?
  • souldude
    • Jun 2011
    • 37
    did u send channel list from computer or did u upgrade by usb?
    there seems to be an error when sending files from computer to box as i have had a few that has frozen and had to return.
    • visiondvd
      • Apr 2012
      • 15
      I updated channels via usb and cfg via lan tool, that's when it froze.
      Ok got it sorted
      with lnb cable disconnected and lan connected.
      I reflashed several times, using several firmware to no avail.
      I then got info advising the following.
      Using lan tool and putting box in standby, standby is important. I log into box, and replace image file with image I backed up a while ago, the box reboots, so you have to put it into standby again.
      I then replaced, via lan tool, all the other files with blank files cfg etc.
      Reboot box, its working again, both boxes.
      I had come across this with f5s b4 but binned them.
      I should of kept them.
      • saayinla
        • 162
        Will try this out, had to return about 3 boxes due to the above issues. Will feedback if this works, also will try flashing box firmware and channel list by USB see how that works.
        • coolboyonnet
          • Aug 2013
          • 6
          Ok got it sorted
          thanks i was trying for week and after your post got sorted
