Openbox V8s Webtv m3u
  • skyfatman
    • Feb 2013
    • 37
    Any one point me if i can update webtv m3u files and how . thanks
  • lalas
    • 21
    I am having the same challenge, not sure if V8s takes m3u files and where to find the files. You can update by USB in web tv I guess.
    Any help woulf be great. thanks
    • hfxlad
      • Feb 2014
      • 91
      there is a rar file in downloads which i uploaded.
      • tims2k1888
        • Dec 2013
        • 4
        soz to b pain when i update with usb it said webtv.m3u failed any helps pls.Thanks
        • martin035
          • Apr 2014
          • 1308
          You need unrar the files that hfxlad has provided in post #3 then place the files on the root of the USB drive ie not in any folders.
          • tims2k1888
            • Dec 2013
            • 4
            done that but still says the same.could it b the firmware on my box or anything els?
            • hfxlad
              • Feb 2014
              • 91
              tims2k1888
              this rar file is how to edit your webtv unrar the HOW TO EDIT WEBTV and it will explain everything for you ther is 2 files in the download.
              • futureneo
                • 6
                Hello.
                I know how to edit and create m3u files.
                I read the files provided by hfxlad.
                The problem is the same.
                When I try to read m3u file from dongle Open box V8s say it failed.
                Anyone with any ideas? I try to goggle this problem, lots of people complaint but no one really give a solution.
                • hfxlad
                  • Feb 2014
                  • 91
                  when you say dongle? do you mean usb?
                  • futureneo
                    • 6
                    Yes.
                    Copy file from PC to "usb stick" and try to update from there.
                    • hfxlad
                      • Feb 2014
                      • 91
                      does the box recognise the usb when you plug it in?
                      • futureneo
                        • 6
                        Yes. I am using the usb in the front (box say A). Is any difference between them?
                        • hfxlad
                          • Feb 2014
                          • 91
                          try useing the back 1
                          and also try formating the usb aswell
                          and if you can try another usb.
                          • futureneo
                            • 6
                            Thanks. i will try that and post if it work.
                            • hfxlad
                              • Feb 2014
                              • 91
                              ok good luck with it
