Hi guys does these channels work for anyone on skybox f3? I get a message saying invalid programme search again! Done a update on channel list, scanned for channels but no luck any help will be appreciated thanks!
Zee tv, zee cinema, zing not working
Hi ZEE channels 28.2 east frequency 11661H sr27500. Working fine on Spiderbox and TM Hope this helps. -
hI. The answer is that your dish or LNB needs tweaking a fraction. Do you know how to doo it???
Regards.Comment
The following channels have moved transponder, these are now fixed
Pavers Shoes.TV
Geo News
ARY Digital
V Channel
Made in Tyne & Wear
Zee TV
Zee Cinema
Zing
Zee Punjabi
Lamhe
Babes From TV
The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remoteinformation given is to be used for educational purposes only
If It Ain't Broke Don't Fix ItComment
hI if the new frequency has scanned in the channels ok but picture quality is bad then its your alignment needs adjusting via dish or LNB . It could be your dish is a bit loose and causing you to lose picture quality. Do you get over 800 channels working ok even if they say SCRAMBLED... i doubt it very much. Remember because channels were working before on old frequency it does not mean they will work on new frequency unless dish is aligned correctly. Do you have easy aceess to your dish in case adjustments are needed
RegardsComment
