anyone got the manchester united game on or any idea how to find it? skybox f3!!
3pm football games
Dont make much differance mate
But would advise a paid one as the free ones tend to buffer freeze and kick you out of the program .
Not that expensive you can have several users onmost V.P.Ns so you could say 30 quid a year divide by 5 = 6 pound a man.
Shows Every Prem 3 o clock kick off just pick the one you want
All 3 pm kick offs available to watch the next day as well
Does my needs , i find the quality exellent for streams ,and i have a motorised set up .
But as in post 5 the more you stretch the pic the quality will drop as on most divices
Sorry if not on Skybox F3 subject But is a great alternative without the expense of sat setup
Hope this helps.................PaulIf your Happy with the Help push the Thanx button
PAUL
Cheers pal. Got all that set up now and good job.Dont make much differance mate
Thanks. Much appreciated.Comment
Not sure about an account mate.
just install xbmc onto your machine combined with a vpn and that will work
you can buy cracked NBC accounts but you will still need to run it through a usa ip
for it to work
on android it doesn't install like a program it judt sits on your machine
but the option for vpn is then available and working.........PaulIf your Happy with the Help push the Thanx button
PAUL
You can install xbmc vpn manually and set up manually below is the free one , But was crap to be honest did work ,may help you to start off,paid version may be better
h**ps://www.dathovpn.com/download-vpn-software.html (replace the stars with tt)
Paid versions tested with great results for 3 pm kick offs 99% freeze free football i found with below
Pure VPN
Also Ghost Path is the one ime useing now with Exellent results
Just keep changing the usa server and ping via speedtest till you find the smoothest
Dont forget you can have it on several items so share with freinds to bring down the cost ,Paid one will get you great results for all 3 pm kick offs , (h**ps://ghostpath.com/)
This thread may be better moved to XBMC for better results and feedback Hope this helps ,Thanks ...............................PaulIf your Happy with the Help push the Thanx button
PAUL
