rebooting openbox f5s
  • amby1999
    • 11
    hi guys got slight problem with my brand new f5s box turns on now ,but when i put bbc 1 hd or bbc 2 hd ,itv on and some $ channels it reboots again and continues to do so unless iam quick and change channel ?? head done in any help very much app
  • Nutsandbolts
    • Oct 2011
    • 1168
    Hi.. It could be faulty patch or corrupt channels. Is it the same channel its happening on??. Had similar problem on a TM box a while back. You could try the following to eliminate one or the other:
    a) Switch off the box.
    b) Remove the LNB cable at back of receiver.
    c) Switch on box - you wont get any pictures as cable has been removed. Leave it on for a few minutes and see what happens.
    d) If it goes off then its a faulty patch - if it stays on then its probably a faulty channel(s). You may ned to delete channels and retune them in again.
    In the TM problem was due to faulty patch and had to reload a different patch and problem resolved.
    Regards.
    • boobishabang
      • Nov 2011
      • 43
      Regards.
      I had a similar issue recently and it turned out to be the Ethernet cable causing the issue, I was using it plugged into a wireless AP and the voltage coming via the LAN was causing the reboot, I switched to the wall plug connectors for the Ethernet and this solved the issue
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi must say very unusual for an Ethernet cable to do this although i do recall that a guy had similar problems after he plug the LNB cable into the OUT instead of the IN connector. Just goes to show that cables can do weird things at times.
        Regards
        • amby1999
          • 11
          hi cheers folks alll sorted for now thanks again
