Luca Sky UK Channel List (CWAITE/sattv5 + AJ)
Disclaimer:
Made for and tested with Skybox F3S only, I take no responsibility if anything goes wrong by using this channel list with your receiver. It may also work with other Skybox, Openbox, and Libertview models but make sure first. Created in MediaBox Editor Studio.
Took me a full week to find out how to create a channel list, create it, and finally get it to my liking. Tried dozens of tools, edited each channel one by one, and learnt a lot. Totally exhausted and I dunno if I will be updating this list. I hope AJ or CWAITE can take adopt this list and update it. Definitely fits (and completes) AJ's channel list more (yet keeps the Sky numbering for CWAITE).
Features:
Favourite Groups List:
Usage and notes:
Preview:
TV Favourite Groups list (Favourite view)
All TV channels list (Satellite view)
Disclaimer:
Features:
- Based on CWAITE's channel list of 14-3-2015
- Uses Sky UK numbering where possible (http://tv.sky.com/tv-guide)
- Uses the AJ OCD/group-ordering system (takes priority over Sky numbering system)
- HD priority over SD
- No Adult channels nor Adult favourite group (neither in any favourite group nor outside them)
- 32 Favourite groups, 24 used
- English priority over Irish, Scottish, and Welsh
- 1577 total channels (TV, Radio, Data, etc.)
- 59 satellites (Astra 1C 2.0E - Intelsat 9 58.0W)
- 93 transponders (28.2E only)
- ENTERTAINMENT
- LIFESTYLE CULTURE
- MOVIES
- SPORTS
- NEWS
- DOCUMENTARIES
- KIDS
- MUSIC
- RADIO
- SHOPPING
- RELIGION
- INTERNATIONAL
- GAMING n DATING
- SPECIALIST
- SD
- HD
- Regional
- Sky Box Office
- Red Button
- Sky Anytime
- Irish
- Scottish
- Welsh
- Test
Usage and notes:
- Favourite groups 25-32 ('Fav group 25', Fav group 26', ...) have not been renamed and only become visible when something is added to the group.
- To get to Radio channels you have to press [Sat List] first before pressing [TV/Radio]. Same thing for when you want to get back TV channels.
- You cannot see the 'Radio' favourite group in TV view and you cannot not see the TV favourite groups in Radio view.
- Getting to a channel by entering the Sky channel number will not work if you are on a channel having entered it from the Favourites menu (Favourites view). You need to be in the 'Satellite view' (press [Sat List] button) to be able to enter the Sky channel number (this doesn't work for all channels as Group Ordering (OCD like AJ) system has priority).
- SD favourite group holds the Standard Definition channel alternative only for the HD channels that have a SD alternative. The group does not hold every SD channel for the whole satellite.
- 'BoxNation HD' only becomes recognisable as a valid TV channel that doesn't give an error when a program is broadcasting (it isn't a 24hour channel). Check EPG listings (Sky TV EPG link above) for when it will next broadcast. The standard definition 'BoxNation' is a 24hour channel and works with no problem.
- The channel name character limit is 16 and the favourite group name character limit is 15. E.g. 'Sky Box Office 10' is now 'Sky BoxOffice 10', 'BBC Red Button HD' is now 'BBC Red ButtonHD', etc.
- The Favourite groups have been hard named i.e. via Skybox, meaning favourite group names won't reset to CWAITE's and so resetting to factory default is not needed. This works if you delete all your channels first and select to not keep settings when installing this channel list. Always make a backup dump of your current channel list (TP_PROG.dbs) first.
- When watching a channel selected from a Favourite group, pressing [PG+] will switch to a channel in the group that comes after the Favourite group you are currently in and pressing [PG-] will switch to a channel in the group that comes before the Favourite group you are currently in. For example, if you are watching 'BBC One HD' which is in the ENTERTAINMENT group, pressing [PG+] will switch to 'Sky Arts 1 HD' which is in the LIFESTYLE CULTURE group and if you are watching 'Sky Arts 1 HD', pressing [PG-] will switch to 'BBC One HD'.
- To switch channels within the same Favourite group, e.g. BBC One HD > BBC Two HD > BBC Three etc., use the [UP]/[DOWN] buttons. Browsing past the end of the list will take you back to the beginning of the list and vice-versa past the beginning of the list will take you to the end of the list.
- Pressing the [LEFT]/[RIGHT] buttons whilst watching a channel will change the volume. The [VOL+]/[VOL-] buttons will also still control the volume.
- You can jump a page up or down by pressing the [PG+]/[PG-] buttons whilst in the Favourite group menus to get to the next/previous page of Favourite groups, e.g. jump from ENTERTAINMENT (make sure it is highlighted) to Scottish by pressing [PG-] twice, or you can jump to the next/previous page of channels within a Favourite group with the [PG+]/[PG-] buttons (make sure a channel is highlighted first).
Preview:
