I need the most up to date firmware for the openbox S12, I have tried a number of them but only some of the free channels work and the rest say no signal...... I think its a firmware issue but cant find anything after 3/3/14. any and all help appreciated thanks.
Openbox S12 latest firmware needed
there is none
feb 15,2012 was the last official firmware for the s10/s11/s12 which all use the same firmware.
Hi all dug out an old S11 box and having grief. The latest channel lists show mostly "no signal" errors so I assume it's a firmware issue. I am desperate for the asian channels to work as it is for a friend but I also noticed inconsistencies. AJ's List 26-3-15 (No Adult) works fine on sky sports cricket, but not -
firmware has nothing to do with not getting channels.
If you do a blindscan and the dish is set up/aimed properly you should get the channels if the receiver is capable.
Not in that viewing area but the openbox doesn't like to be connected with other receivers to the same lnb for some reason.
Probably a lack of grounding block where the cable comes into the house.Comment
