Upgrade by network
  • digitalss
    • Mar 2014
    • 14
    Upgrade by network
    what does the upgrade by network menu do, and how do you use it.
  • Hadron
    • Nov 2012
    • 2102
    Originally posted by digitalss
    what does the upgrade by network menu do,...
    Nothing!
    ...and how do you use it.
    You can't!
    I assume that it was intended to be used to upgrade the firmware over the net, but unfortunately it has never worked for anyone.
    • bluerein
      • Jan 2015
      not true.. the feature does work but not well documented anywhere..
      it requires a config file located in the same directory as your .abs file on your server..
      ive only tested it on a v8s but im using the same file for the f5...
      • digitalss
        • Mar 2014
        • 14
        Please share your insight, would be much appreciated
