Help with skybox a3 flashed fine but soon I put channel file then it's hang and remot
  • coolboyonnet
    • Aug 2013
    • 6
    Help with skybox a3 flashed fine but soon I put channel file then it's hang and remote stop respond
    Skybox a3 flashed so far working now I setup for first time
    done channel scanned
    Soon I put any channel it's work 20 sec and then everything freez even remote stop responding
    Help please
    Thnx
  • Nutsandbolts
    • Oct 2011
    • 1168
    Hi. Is it correct firmware you put in. Also you can try the following:
    1) Switch off box and remove LNB cable behind the box.
    2) Switch on box and see if remote works and channels change and menu options etc. If channels/remote stop working then you may have a corrupt firmware and reflash the box with different firmware.
    3) If box appears to be working then leave it on a channel and insert the LNB cable and see if picture appears. If no picture check receiver display for message like LNBF - this message usually will block your receiver/remote and its to do with a faulty cable. Hope this helps you.
    Regards.
    • coolboyonnet
      • Aug 2013
      • 6
      thanks for reply but got all sorted now from this post
      Hi all I have two v8s and both, after installing ch list freeze when connected to lnb. If you disconnect lnb, menu works fine, but once lnb connects everything froze, menu and all. I have to disconnect cable and reboot box to get to menu. I have tried a couple of different firmware, and tried loading via usb and flashing. Tried
      Using lan tool and putting box in standby, standby is important. I log into box, and replace image file with image I backed up a while ago, the box reboots, so you have to put it into standby again.
      I then replaced, via lan tool, all the other files with blank files cfg etc.
      Reboot box
