Which Box?
  • canford
    • 263
    Which Box?
    Hi guys brother in law had an skybox f3, which is now cream crackered, he likes the ease of use of the skybox f3 and the available channels lists, could anyone recommend a like for like box, the skybox f3 is a little hard to get hold of , so anything that is really easy to use would be a big bonus, thanks.
    Get a Cheap Linux E2 receiver something like a TM-Nano-SE for about ?89 and you have no need of channel lists with autobouquets
    • cushty
      • May 2014
      • 30
      using a skybox v6 at the moment cheap and cheerful you can pick them up for about ?40 and really easy to use if that helps
      • canford
        • 263
        Thanks for the suggestions the skybox v6 seems like a good option, can you readily get hold of channel lists like AJ's?
        • shaunfree
          • 358
          yes thanks 2 AJ hard work list will work on v6
          • Hadron
            • 2102
            The only place you can still pick up F3 boxes is probably Ebay.
            If you still want an F3, I see there are a couple up for auction as Openbox F3.
            btw...what's actually wrong with his old F3?
