Hi all,
Just thought I would share this info with everyone. I have had the openbox v8s for 2 days and all was well, that was until 2 hours ago when the box switched off and then restarted again, it managed to load fully until program descrambled and then reset loop continued. After reading various posts on this subject I like many thought I had scrambled the firmware. However after disconnecting signal feed from rear with no effect I then took out the USB pendrive and it stopped looping and all is as it was prior to the initial reset!! The pendrive is now u/s and is not recognized by my pc or laptop.
It appears that dead or dying USB drives will give the same symptoms as faulty or scrambled firmware:-(
Hope this is of use to others.
