Hi I am new to this got v5s put it on last night and it says loading then it loads 1 to 100 then goes off then starts again 1 to 100 and is still doing it any one got any ideas or should I just stamp on it Thanks
openbox v5s keeps loading wont start up
There are 2 common reasons for this.
Could be a short circuit in the LNB cable. Try removing the F plug, cutting the end off the cable, redoing it & refit the plug.
Might also be due to a failing mains adapter. If you have another one with the same voltage (12v), with +ve to centre pin, & rated at 2A or more, then try that.Comment
