Openbox V8s Channel List
  • toe471
    • 254
    Would it be ok to use aj's list on this model guys as I tried updating the list a few months back with aj's list and upon restart it froze on the LOAD screen at startup?
    I think I know why it did this as I had 2 usb sticks plugged in and it seemed to have confused it? I removed the recording stick and used the one with the Tp_Prog file on it and this time it was fine
    Is there a particular list we are suppose to use for this V8s version?
  • Nutsandbolts
    • Oct 2011
    • 1168
    Hi Why dont you just do a blind scan and tune all the channels in...
    Regards
    • mjon
      • 58
      Originally posted by toe471
      Would it be ok to use aj's list on this model guys as I tried updating the list a few month Reply With Quotes back with aj's list and upon restart it froze on the LOAD screen at startup?
      aj's or cwaites list are both ok to use, so you dont screw the box up make sure you delete all channels first and before adding new list to usb stick delete any existing TP_Prog file on it.
