No signal
  • stevieoc70
    • Mar 2010
    • 12
    No signal
    I am getting a no signal on all premium channels Openbox v8s this is the second box with the same problem and I have had an engineer check connection which is perfect.
    Could this be a firmware issue or an incorrect list ( used AJ'S) or am I holding a brick? any advice welcomed thanks
    Steve
  • P&D
    • 2686
    Hi do you get the FTA channels ??
    • Nutsandbolts
      • Oct 2011
      • 1168
      Hi Why dont you try and do a blind scan and see how many channels you get. If the engineer said there is nothing wrong with the alignment then the blind scan should work ..if not then its your box or dish alignment.
      Regards
      • cwaite
        • 360
        Steve
        Do you have any other satellite boxes connected to you LNB, if so unplug them from the Mains (don't just put them in Standby actually unplug them from the mains) then see if the channels that are currently showing No Signal start working.
        If you need help installing channel guides or have a problem, take a look at my video guides
        https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
