Firmware update for openbox V7s
  • mikeon11
    • Jan 2012
    • 18
    It is possible to update openbox V7s with openboxV8s firmware. This box is working but the EPG is not loading channels information.
    Any way around the firmware update or the EPG?
    Thank you in advance
    mike
  • P&D
    • 2686
    Have you tried the latest firmware ?? http://www.yojiatech.com/index.php?r...load&cat_id=68
    Dated 2015-06-01 01:41:44
    • mikeon11
      • Jan 2012
      • 18
      That is the reason i asked the question, to know if anybody ever tried the firmware for v8s on v7s. I will probably try to see if that will work.
      mike
      • mikeon11
        • Jan 2012
        • 18
        searching through the dowload section i found these three files but, i'm not sure which one i should download.
        {1} S-V7(14112700FA_VFD)
        {2} S-V7(14110505_VFD)
        {3} S-V7 (140924065F_VFD)
        Any help will do.
        mike
        • P&D
          • 2686
          mike
          back the firmware up for the V7
          then try the flash for the V8........if no good flash it back with the V7 backup
          • mikeon11
            • Jan 2012
            • 18
            I have tried v8 firmware but, received mismatched
            • bigade1
              • Oct 2013
              • 340
              New official Skybox V7 firmware released today:
              • mikeon11
                • Jan 2012
                • 18
                Absolutely perfect, this update sorted out the EPG problem.
                Thank you
