openbox x5 Authentication fail
  • mahabad1972
    • 39
    hi i downloaded the latest firmware for openbox x5,(KD_P9000E_HD_OPENBOX_X5_2015_01_04) after update via usb, even i used recovery as in some of the website, still shows Authentication fail
    i even downgraded to lower firmware still the same, only one firmware worked but after update with this firmware ( KD_P9000E_HD_OPENBOX_X5_2013_11_11) the box keep rebooting itself with this firmware any idea
  • ziafat111
    • Mar 2016
    Try the 2014 version that works
    • staden321
      • Nov 2015
      • 73
      Where are you getting firmware from????
      Sent from my SM-G850F using Tapatalk
      • ziafat111
        • Mar 2016
        I can't remember but I could upload it for ya
        • nildopio
          • Nov 2013
          • 6
          Hi ziafat111
          , can you upload the firmware for me too? thx in advance.
          • mini
            • 602
            it might bot be the firmware causing the reboot, could be psu. Try the original firmware if still same issue then check the psu.
            for firmware
            try yojiatech.com or skybox.cc or have a look in the download section.
            New firmware 6/5/11 1.Optimize "read smart card function" for example, Viaccess 4.0,NDS 2.0 , Irdeto 2.0, Conax 5, Sega ( i.e.Mediaguard 3) Nagra 2 and so on 2. Add "FTP function', you can upgrade your software and files by internet, including software, system file, TP_PRO.dbs, Cccam.cfg, softcam and so
