moveing chanels
  • ringryan
    • May 2015
    • 32
    moveing chanels
    hi is it possible for me to replace a channel with another
    i have itv central on 3 in entertainment and want to put channel 36 itv in regional in its place
    can this be done
  • stavros67
    • May 2013
    • 81
    can this be done
    It sure can,just not easy to explain via email
    • ringryan
      • May 2015
      • 32
      is there a guide on here on how to do it
      • mikeon11
        • Jan 2012
        • 18
        I believe moving the channel, in the channel edit, would do the work. It is possible to manually move channels around.
        • digicon
          • 8261
          This Thread here may be of some help: http://www.digital-kaos.co.uk/forums...3-F3-F4-amp-F5
          • brodev
            • 17
            I do this regularly. There may be a simpler way but here is how I do it on a V5S
            Firstly I select favourites and then entertainment and any channel. Then
            1 Press menu button and select "edit channels" and then select Favourites edit. Ithen get presented with 2 lists .On the left hand side is All Satellites and on the right Entertainment. In between the lists are the + X signs
            2 I scroll down in the All Satelites list till I find the one I want (for example 1012 has Anglia W) and then press ok when I get a green tick
            3 I move to the middle and highlight the + and again press OK which results in my selected channel getting a red heart Fav sign
            I then exit making sure to save
            4 got to Channel edit press RED buttonto select fav then entertainment
            5 select the prog I wish to replace (0003) then move to the other column and select the 2 arrows or Move sign and move the channel to somewhere else (I move it up to the last position available) and press ok
            6 near the end of the list the channel you selected earlier (ITV Anglia W0 will be found.Again select it and move it to position 3
            exit and make sure to save
            job done
            • ringryan
              • May 2015
              • 32
              i have a skybox v6 do you think that might be tge same
              • brodev
                • 17
                I have no idea. I suggest you try it and see
                • ringryan
                  • May 2015
                  • 32
                  this wirked a treat thanks for everyones help
                  • ringryan
                    • May 2015
                    • 32
                    worked even
