Why is everything showing $ ?
  • bhavik0
    • Oct 2013
    • 30
    Only my FTA are working, any ideas? Also how can you tell if your subscription has ended?
  • pwathw
    • 11
    press menu on remote move right to network local settings press ok move down to camds setup if not showing press 6666 on keypad
    move to CCcam client setup press ok move down to manage config files prees ok find CCcam.cfg press ok it will tell you if your cline
    is online or offline.
    hope this helps you regards pete
    • martin035
      • Apr 2014
      • 1308
      Sometimes it's a basic internet problem. Try rebooting your Sat box and router and see if the weather app, youp**n or the xmltv epg updates work if these ok then check pwathw idea.
