Skybox f5s reboots every time on channel search
  • oweny
    • 71
    Hi guys no been on for a while had my skybox f5 now for a year and the other day it started to constantly reboot I've tried flashing with my null cable but won't connect the box rebooted like every 5 mins if I'm lucky I turned it all off and turned it back on today and it's not reboot yet I can't seem to rescan for channels as I do it gets to about 5% then reboots any other ideas I can use also my channel list have changed thx in advance
  • seangraves
    • Sep 2012
    • 275
    try updating to latest firmware then uploading channel list mate ....
    • oweny
      • 71
      I have tried that with the latest from skybox..cc I've tried the list half may channels end up saying invalid channel now it's starting to reboot every 20 mins or so
      • Hadron
        • 2102
        The rebooting problem could be a sign that the mains adapter is on it's way out.
        If you have another one around (12v +ve to centre pin & with a current (Amp) rating of 2A or more) then you could try that.
        • oweny
          • 71
          I was using the orig power supply until that went I found one at 10v and it worked for about a month then started to have this problem I only have another 12v but it's 500 a so if I purchase one from eBay should that fix my problem
          • oweny
            • 71
            How do I update my channel list I no longer have sbo just comes up invalid channel it was there I watched the last we main event on it
            • Hadron
              • 2102
              I can't say for certain that a new power supply will cure your problem, but the fact that you are using a 10v one instead of 12v one could mean that it is the psu causing it.
              You can use any 12v 2A psu as long as it has the 5.5/2.1 connector on the end, which most of them do. I wouldn't go for one that is specified for the skybox/openbox, as you can get better quality ones for around the same price (or less), such as this one:-
              http://www.ebay.co.uk/itm/GENUINE-12...item2a505c2f63
              It uses the same connector as your box.
              • Hadron
                • 2102
                The second post in AJ's channel list thread in the stickies shows you how to install a new channel list.
                Are you sure that there is something on sbo at the moment? If there isn't then it will show invalid channel.
                • oweny
                  • 71
                  It usually says scrambled not invalid I watched the wee on it then my box started going funny I reset all setting and now the sbo channel says invalid
                  • oweny
                    • 71
                    Hi again m8 I'm using a 12v 3a adaptor now and it still reboots on channel search and every 5 mins
                    • oweny
                      • 71
                      Hi m8 so I've tried a orig new adaptor power supply and reflashed box through null cable and added my channel list but my box still keeps on rebooting do I need a new box ? Is there maybe a resistor or something blew in it ? It reboots every 2 mins now
                      • Hadron
                        • 2102
                        The only other thing I can think of, is the LNB drawing too much current, but as it appears to be working normally, then I don't think it's very likely. If possible, you could try your box on a friends dish for a while to see how it goes.
                        It's unlikely to be a faulty component I would think.
                        Does your box still reboot with the LNB cable removed? If not, then it might be worthwhile removing the F plug, cutting an inch or 2 off the end of the cable, then preparing the end of the cable & refitting the F plug.
                        • oweny
                          • 71
                          reply
                          yeh m8 it still reboots withe cables out
                          • antomac
                            • Oct 2013
                            • 315
                            just unplug everything from your box and leave for a minute and retry
                            I know its simple but I had a f5s that kept rebooting and this worked for me
