No signal on movies
  • geosidey
    • Nov 2013
    • 5
    No signal on movies
    seem to have lost movis and a few other channels I've put on the updated channel list and all seemed fine but now nothing, if I do a tp search 11934v is showing practically no signal and can't find any channels any suggestions guys
    Try another chnl list mate plus these boxes are poor do a bit of research there are far more reliable boxes out there for just a few quid more. just my opinion though .
    • geosidey
      • Nov 2013
      • 5
      tried another chnl list deleted the tp list and did a blind scan still nothing when i go through the tp list most of them have around 85% signal and about 80
      % quality but 11934v only has 40% and 10% quality nothing has chnged on my setup only got the probs when movies changed freq
        came back from hols on Thursday and the films were not working,not updated box for about 3 months but they came back after deleting all channels then doing a blind scan on 28e single sat search. found them around the channel 700 mark,hope this helps
        • mozzer
          • Mar 2010
          my movies gone now skyf5 where can i find a new updated list?
          • joe516
            • 1000
            17/06/2015
            Most of Sky's Movie Channels Changed Transponder
            The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
            or manually scan the transponder its 11934 V 27500 m8
            • geosidey
              • Nov 2013
              • 5
              k movies now working no idea what happened but updated channel list with AJs one did another blind scan unplugged the f5 and went to the pub to ponder the problem came back plugged it in and all fine now so from now on if i get a problem im going to the pub
              • intel
                • Apr 2010
                • 128
                Probably the box just needed a reboot?
                • cactikid
                  • 12017
                  these boxes people will always get moved/missing channels because of old data,people should have this on pc to check for movement
                  http://en.kingofsat.net/tv-28.2E.php
                  • Motoxuk
                    • Jun 2015
                    • 10
                    Hi I am having the exact same problem can you tell me what channel list you used,thanks
                    • P&D
                      • 2686
                      Check the red stick's on the openbox forum its not rocket science......
                      3 to choose from
                      CWAITE (previously sattv5) Sky Numbered Channel List **Only** Thread
                      AJ's Sky UK Channel List **Only** Thread - Updated Regularly
                      Hall-E's List: http://www.digital-kaos.co.uk/forums...-latest-update
                      Did you take Nutandbolts advice on this post ??....http://www.digital-kaos.co.uk/forums...=1#post2549479
                      • Motoxuk
                        • Jun 2015
                        • 10
                        Okay so if I do a tp search on 11934v and no channels are found from sat,then it should not really matter what channel list I use,my dish is fine and finds most of other channels just not some of the movies and sports.
                        • P&D
                          • 2686
                          So i guess you don't take advice.......
                          load one of the channel list above if you still have the same problem......then its the problem that Nutsandbolts pointed out to you
                          very easy if you listen to what your advised to do.............if still confused take the box to a mates house & check it there
                          if they have a sat dish & internet....if all working perfect then take the advice your given
                          from Nutsandbolts ...........
                          You can lead a horse to water........but you cannot make it drink it comes to mind
                          • P&D
                            • 2686
                            Sorry but 2+2=5.......NO..... work it out ......if you do a blind scan or upload a channel list pre-loaded with all the channels working
                            the problem your having????
                            wrong channel list your loading(out of date) or the dish is out......Easy Buddy
                            list what channels you are missing
                            do you have the original box connect ??
                            • Nutsandbolts
                              • Oct 2011
                              • 1168
                              Hi For all you novices out there here are some simple tips regardless of what box you have:
                              1) If you think your dish is aligned correctly then it should not matter if you download an updated channel list or you do a blind scan channels should work.
                              2) If your dish is out of alignment then whether you download a channel list or do a blind scan then channels will not work or tune in... you may get some channels working etc. In this case its always best to rely on a blind scan because the number of channels found will tell you if dish is aligned correctly.
                              3) If you think box is faulty then take box to a friend/relative house to check it out. Or check a friends box at your house to check lineup etc.
                              Most fault finding are just a case of common sense and elimination process.
                              Regards.
