Tv was working fine last night internet speed was low so rang vm to sort speed issue out which they did when ive come bk in for work ive got no signal not even free channels internet all working xxxx working any ideas snr says 10% but will that jst be because i have no sigal thanks
Problem
The FTA channels should work without any internet connection.
There must be a problem with your satellite dish/LNB/cable. Has anyone been "playing" with the box while you weren't there? Has the LNB cable been plugged into the LOOP connector. Is the LNB power still set to "on" in the menu?Comment
Hi. You should get a strong signal from your cable/LNb even if you dont get a signal from satellite. There are usually two types of signals one from LNB/cable and one from a frequency reading from satellite. You need to get the LNB signal otherwise the satellite signal wont be picked up. Even if you have a tree in front as this will only stop the satellite signal but not LNB. I dont think its your tree as if it was working yesterday ... Your best bet is to concentrate on the cable aand make sure its connected properly.
regardsComment
Strange one, right forget wifi/ethernet/internet this isn't require for free to air channels.
Do you have twin cable feeds coming from the Sat dish? If you do try one cable then the other.
Other thing to try is delete all your channels and do a blind scan and see what it finds.Comment
