Virmin Superhub and F5s
  • fishybiscuit
    • Apr 2014
    Morning all. Hope someone can help, or at least point me in the right direction.
    Currently have Virmin super-hub in modem mode.
    Attached to it is a D link router with DD-WRT firmware, With a homeplug from it to my F5s. so far so easy. everything works fine(ALL channels).
    I decided (in my infinite wisdom) to try the super-hub out of modem mode (big mistake). Now only normal channels available. However, the apps work (weather, XMLTV), but everything else offline.
    Reset everything back to how i had them previously (modem mode, router, homeplug etc) and all back to normal (Channels back and apps still work)...
    My Question is what is going wrong, it seems the super-hub doesn't like the F5s(specifically the channels, maybe I'm wrong, but that's how it seems.
    i have browsed other forums for answers (admittedly from a couple of years ago), but no one had any real solutions.
    Does anyone know why this happens, and if so how do you correct it.
    thanks in advance all
  • shaunfree
    • 358
    hi mate i use hub without router and no probs on openbox 11 and f5 and not heard anything about vermin blocking just a f5s cheers shaun
    • portvalefanjosh
      • Dec 2013
      • 101
      My f5s box has always worked fine with the super hub, wired connection straight from the hub too the box no problems ever.
      • joe516
        • 1000
        f3 and f5 worked fine with the super hub m8
        • cactikid
          • 12017
          ah but old super hub had issues and people were asked to put hub into modem mode and use a router,box and router may need powering off then on to make a connection.
            Old S/Hubs where ~~~~~ wifi was none existant..
