Skybox f5
  • Siboo68
    • Jul 2015
    • 21
    Skybox f5
    Multi channel list for skybox f5 please?
  • martin035
    • Apr 2014
    • 1308
    If your after a single sat channel list for 28e then either AJ's or cwaite's will do, both are available in the Red sticky section at the top of the forum. If your after a multi sat channel ie your using a motorised system which point your dish at different sats then I don't think there is one, but I happy to be corrected. What I have know people to do is is make their own, by install a 28e channel list then doing a blind scan on other sat co-ords.
    • Siboo68
      • Jul 2015
      • 21
      How do I create my own list and yes it is motorised.could you advise me please with a diagram of some sort.thank you so much,I am new to all this.
      • martin035
        • Apr 2014
        • 1308
        Unfortunately I don't use a motorised system I'm quite content with 28e and Kodi, hopefully one of the more knowledgeable members will be alone soon to advise or you could use the forum search tool with key word 'motorised' and start reading, there's loads of info out there.
        • P&D
          • 2686
          When i used Aj's list a few years back
          all the sats are in the file.....http://www.digital-kaos.co.uk/forums...=1#post2553471
          You just need to blind scan the sats you need then you have a motorized sat lists.....you could possible upload it i'm sure others will use it
          • Siboo68
            • Jul 2015
            • 21
            hi how do i get 28e on my skybox f5 do you know how to do it?
            • martin035
              • Apr 2014
              • 1308
              Install either aj's or cwaite's channel list both so the same thing just the channel numbering is different.
              Both lists and the relevant instructions are available in the red stickies section at the top of this forum.
              • Siboo68
                • Jul 2015
                • 21
                ok thanks i will try that
