favourite list v8s
  • elad
    • Sep 2012
    • 41
    favourite list v8s
    I've deleted my favourite list from v8s can anyone tell me how to get it back or send me a file plz 28.2
    cheers
  • Hadron
    • 2102
    Just reinstall either AJ's list or CWAITE's list from the stickies above.
    The 2nd post in AJ's thread has instructions for installing.
    • elad
      • Sep 2012
      • 41
      I've done all that even updated firmware but still no favourites list i wonder if its to do with the mac book I'm using or should i use a window machine ?
      • Hadron
        • 2102
        It shouldn't have anything to do with the machine you use to download.
        As long as you transfer the channel list to a memory stick (or USB HDD) & then Update by USB, tHen it should work. It should take around 10 seconds to transfer the TP_prog.dbs file to the box. When you press the "info" button afterwards, it should show "OK".
        • amit chauhan
          • Apr 2010
          • 83
          Try unzipping the channel list if it zipped into a folder
            You need to install winrar for file to be recognised or else it will not work…
