f3 box not workking - ethernet connection? homeplugs (virgin broadband)
  • wakkaday
    • 148
    it was working but now its stopped. any advice? dhcp is on, when i turn it off it says invalid ip etc
    any advice? i dont have a wifi dongle to check if thats works so only ethernet at this stage
    main router is upstairs and the box is downstairs
    i hoppe you can advise?
    thank you
  • MarmiteX1
    • Aug 2013
    • 41
    Firstly, In your router look for the setting along the lines of "DHCP settings" or "IP settings" in your router. Make sure the option "DHCP Enabled/DHCP" is checked/ticked.
    Secondly, I suggest you switch everything off then turn everything back on
    e.g Router and the set top box.
    Then turn the router back on.
    Then turn on the Skybox.
    Wait for 5 minutes.
    Check the lights on the homeplug that are connected to the router as well as the Skybox.
    Hope this helps.
