Ok, here's a problem I've had lately in one of my bedroom set-ups.
I have an Openbox V5S and a Panasonic DMR-EX77 DVD/HDD Recorder. I have them connected to a little
Scart switcher box thingy which then feeds a TV, and also have the two boxes connected together to allow
me to record from the Openbox should I desire.
However, when I plug the Scart lead from the Panasonic into the Openbox Scart output, the picture that comes
from the Openbox to the TV darkens slightly. It doesn't darken when I switch to the Panasonic with the AV1
input selected. In other words, the Openbox picture display is fine when viewed through the Panasonic box but
is darker when viewed directly from the Openbox.
The picture brightens back up to normal levels when I unplug the Scart lead that connects the two boxes
together, regardless which end I unplug. It also makes no differenceif the Panasonic box is on, at standby or
completely powered off. It's maybe a bit hard to follow so I've included the pictorial below.
I previously had the "snowy" picture problem on the TV (it's an old TV, not HD or anything) which I solved by
cutting the pin 19 cable in the Scart lead that plugs into the TV. Et voila, perfect picture. I'm wondering if this
latest issue is also some sort of interference in the Scart leads, or is it just an issue with an Openbox?
