Skybox blue no signal message
  • redstripeu2
    • 25
    My skybox m3 has blue no signal message on most channels including freeview channels , very few work but premier hd works ,channel 4 hd works but most of the rest (nearly all ) show blue no signal ,I've tried changing the settings in antenna setup etc but still no signal ,also my YouTube app won't load and box won't upgrade by network anymore . Can anyone shed some light on this matter for me please , I've upgraded my bouquet to latest also
    Thanks in advance
    PLEASE HELP
  • martin035
    • Apr 2014
    • 1308
    Originally posted by redstripeu2
    I've upgraded my bouquet to latest also Thanks in advance PLEASE HELP
    Which bouquet/Channel list are you using? ...........the latest ones are available in the red stickies section at the top of the forum, instruction on how to install are available here in post #2 (same instructions for both lists) and don't forget to unzip the download file first before installing.
    http://www.digital-kaos.co.uk/forums...ated-Regularly
    I've just check skybox.cc and the latest update for the m3 is dated 28/03/2013 which your most probably on already (but you can check via your remote, select menu-information) if your not on this firmware then you will have to do a manual update, instruction on how to do this are here.
    Little guide i made :) Hopefully be of some use :) Download: http://sdrv.ms/VnHIcS
    Whether this fixes the youtube app is anyone's guess, as I'm sure it still doesn't work on the latest firmware on the latest skybox (v8s) but happy to be corrected on this quote.
    • redstripeu2
      • 25
      Thanks for the reply and info il check out the links later after work with my laptop il let u know how I get on
      Cheers bud
      • redstripeu2
        • 25
        I'm using a channel list bought off eBay dated 1.08.2015 by the way
        • wortho
          • 144
          just use one of the ones above mate aj/cwait is a good ones dont pay for them
          • redstripeu2
            • 25
            Il try them later after work pal and let u know how I get on
