openbox s9 stuck on
  • pspmixer
    • Jun 2009
    • 750
    openbox s9 stuck on
    turned my openbox s9 today and it all its says on display is on turned off and back on still stuck on that
    i havent done anything to it just watched it as normal
    can anyone help me
    ive only got a usb to serial cable as dont own a serial pc
  • Hadron
    • 2102
    Have you seen this thread:-
    A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked. Box does not respond or displays On or rebooting constantly ? If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow
    As mentioned, not all USB to serial adapters work. One that is known to work, is this one from Ebay that uses the Prolific PL2303HDX rev D chipset:-
    http://www.ebay.co.uk/itm/3015087678...%3AMEBIDX%3AIT
    You will need to use it with a null modem cable:-
    http://www.ebay.co.uk/itm/1112286796...%3AMEBIDX%3AIT
    Some have said that this "all-in-one" cable also works:-
    http://www.ebay.co.uk/itm/2008273450...%3AMEBIDX%3AIT
    There's no need for a separate null modem cable if you use this one.
    • pspmixer
      • Jun 2009
      • 750
      i have a null cable but my laptop doesnt take the cable without the usb so i guess i take box into work and try with works pc
      • pspmixer
        • Jun 2009
        • 750
        Tried the null cable in work and getting errors ' initialize stb sdram is failed ' and ' set stb memory error '
        What can I do now
        • P&D
          • 2686
          Make sure the COM port is correct....don't know what OS you are using.......control panel/system/device manager/LPT/com
          make sure this com port is the same as the one in the software your using to flash the box
          Which software are you using there are 2 ??
          • DW190
            • May 2012
            • 1263
            Doesn't the S9 have a different loader to the later boxes. I have the attached one on my HDD. Also have the other attachment which may be the bin file for the S9 as well.
            • pspmixer
              • Jun 2009
              • 750
              yes itc om 5 as using this http://www.ebay.co.uk/itm/200827345077 just arrived today
              im using Ali3606_RS232_Upgarde_Tool_20111110 , EromUpgrade and one dw190 posted
              all three not working for do you change the bit rate at all
              • slugworth
                • Nov 2011
                • 1064
                s9 firmware compressed is <2meg size
                so just looking at the size of the .rar it can't be for the s9
                I always use old pc's with a real com port.
                As a matter of fact I just threw 2 or 3 old pc's out.
                No room at the inn.
                • pspmixer
                  • Jun 2009
                  • 750
                  No room at the inn.
                  cn you link me to s9 firmware please so i can try then let you know if works or not
                  • DW190
                    • May 2012
                    • 1263
                    You should have it some where, you uploaded it in 2011. Had your two pennath worth out of that box ehh.
                    • DW190
                      • May 2012
                      • 1263
                      When you have plugged you USB to serial adapter in go to Device Manager (you will find it in Control Panel). Look for Ports and you should see your adapter and the port number. If its not there, then its probably missing the drivers.
                      • pspmixer
                        • Jun 2009
                        • 750
                        the cable is installed correct as shows in device manager but getting errors on all programs i use for fixing this box
                        • P&D
                          • 2686
                          seeing as your local if you want i can have a go at loading the software on the box for you.....if you want to nip down & drop it off
                          using the loader & firmware DW190 has uploaded
                          I will never throw my old comp away because it has a comport .....i always thought it would be handy
                          P/m me if your interested i will send you my details......can't promise you anything but I will have a go for you
                          done loads of the F/boxes without a prob....
                          Phil
                          • slugworth
                            • Nov 2011
                            • 1064
                            and most of the loaders/editors were written back in the win xp days to be used with win xp on a pc with a real com port.
                            I also always have 2 or 3 old pc's kicking around to use.
                            They are often cheaper than buying an adapter if you get them from friends or family members glad to get rid of them.
