SKY F3 BOX
  • WOODWARD395
    • Apr 2010
    • 628
    SKY F3 BOX
    Hi looking for some advice never used this box before, some friends have asked me to delete their old channel list and replace it with new one can anyone advise me how to do this as never seen the box or menu system before. any advice on what channel list to install and how would be very grateful for any advice. thanks
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
  • cactikid
    • 12017
    smash it and give them an e2 box that looks after itself
    plenty of reading here for that box.
    Discussions for Openbox/Skybox receivers, firmware, channel lists and general help.
    • Hadron
      • 2102
      You can download either CWAITE's list or AJ's list from the stickies above. CWAITE's list is sky-ordered (starts on Ch101), AJ's list isn't sky-ordered & starts on ch 1.
      After the file has been unzipped, you should get a file called TP_PROG.dbs.
      Copy TP_PROG.dbs file onto USB memory stick (FAT32).
      Insert USB memory stick into box.
      Press Menu button.
      Select "Delete all" from "Edit channel" menu.
      Select "Yes" to confirm.
      Select "Upgrade by USB" from "Tools" menu.
      Select "Misc. Files" from "Upgrade mode" option.
      Scroll to "Select & Upgrade" & press OK button.
      Select TP_PROG.dbs & press OK to place tick next to it.
      Press yellow button on remote to start upgrade.
      Wait for Burnflash to complete. It should only take around 10 seconds.
      Press "Info" button to verify TP_PROG.dbs has upgraded (should say OK).
      Press "Power" button on remote to put box into standby.
      Press "Power" button again to boot box.
      • WOODWARD395
        • Apr 2010
        • 628
        Great they tried doing it themselves with ajs channel list rebooted and now it says load in front panel and box will not respond, going round tonight to see if I can sort it but any info appreciated.
          You may have to have a look at this thread as well just in case: http://www.digital-kaos.co.uk/forums...ll-modem-Cable
