Skybox F5{s} Channel Problems
  • kenchov
    • 27
    Hello Everyone.
    Just wondering if you could advise on my Skybox F5 (s) I have tried to update the channels. All The $ channels are fine etc but BBC1 2 ITV channel 4 and bbc 3 itv 2 (HD channels) are all coming up no signal...
    I have loaded the channel lists on my openbox and all is fine.
    Just wondering if anyone could advise what the problem is here with these.
  • cwaite
    • 360
    If you have any other sat boxes attached to your dish then disconnect these from the mains (don't just put them in standby, you need to disconnect from the mains) if the channels return whilst all the other boxes are disconnected from the mains then yes you will need a no signal fix cable which you can get from eBay.
    If you don't have any other boxes connected to your dish, Which channel list are you using? If it's CWAITE's tune to channel 1 (not 101) and tell us what numbers appear in the channel name.
    If you need help installing channel guides or have a problem, take a look at my video guides
    https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
