openbox in load loop
  • magoo40uk
    • Jul 2015
    • 7
    Hi i updated my channel list cwaite now my box wont load it is stuck on a load loop the second box that this has happened to any ideas
  • martin035
    • Apr 2014
    • 1308
    ?...What did you do with your first box that had this problem?
    • magoo40uk
      • Jul 2015
      • 7
      i thought it was a fault with the box i have 10 boxes to upgrade ..afraid to go any further
        Try another usb or channel list ??
        • magoo40uk
          • Jul 2015
          • 7
          continuous load loop doesnt boot up will it read usb as it loads?
            You might need to read this mate http://www.digital-kaos.co.uk/forums...ll-modem-Cable
            • martin035
              • Apr 2014
              • 1308
              I don't blame you, would advise you follow this thread on recovering your knackered boxes;
              A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked. Box does not respond or displays On or rebooting constantly ? If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow
              Also would redownload cwaites channel list, as it sounds like some how your PC has corrupted the file, as others haven't posted about a fault with the channel list.
              • magoo40uk
                • Jul 2015
                • 7
                i have the cable do i need a usb adapter to connect it to box if so what do i search for?
                  http://www.ebay.co.uk/itm/2-Metre-US...item542463a833
                  • magoo40uk
                    • Jul 2015
                    • 7
                    cheers thanks for your help this late hour zzzzz
                    • martin035
                      • Apr 2014
                      • 1308
                      Double post, answered by maca
                      • DW190
                        • May 2012
                        • 1263
                        If you get a prolific USB to Serial adapter the drivers are downloadable. I think you may find them in the download section.
                        Window 8 & 10 should auto load the drivers.
                        • Hadron
                          • Nov 2012
                          • 2102
                          I would also recommend an adapter with a prolific PL2303HXD chipset as a lot of the cheaper ones don't always work. I used this one:-
                          http://www.ebay.co.uk/itm/3015087678...%3AMEBIDX%3AIT
                          On my Win7 pc it downloaded the drivers automatically within a couple of minutes.
                          • DW190
                            • May 2012
                            • 1263
                            Snap, I have the same.
                            Another thing with these is make sure to use the screws on the Null Modem Cable to attach to the adapter, without them tends to get bad connection hence failure to connect.
