no signal on certain transponders
  • nextman
    I just noticed this issue when i tried watching bt amc. On certain transponders i get a very low signal. For example
    11082 22000 H (BT AMC)
    11112 22000 H (Cartoon network, boomerang)
    11973 29500 V
    12422 27500 H
    etc. It never really bothered me untill now. I tried switching ports on the LNB but it didnt make a difference. Does anyone have any ideas? I have an openbox v8s.
    the Transponder 11973 is no longer in Use the others are on the 2E and 2G europe beam which will be slightly and i mean only slightly weaker than the UK spot beam equivalent, any standard Zone1 43cm mini dish will give adequate signal on any of those transponders
    • nextman
      Thanks for the reply. Is it possible there is a problem with the box then? Or maybe the dish is slightly misaligned. The majority of channels work fine.
        The only way to eliminate a possible problem with the receiver is to try another receiver on the same dish
        • edwardihno
          • 6
          Try my method http://www.digital-kaos.co.uk/forums...25#post2608025
