New firmware to Upgrade Channel list by Network
Anyone who has upgraded to the new firmware having any issues where the box freezes and the only way to get it to respond is take the power lead off and back in again?
Never had this issue with the old firmware this has only started to happen when i upgraded to this firmware.
ThanksComment
Yes agree kind of defeat the whole object of the updated lists really....So i have quite a old FW (on F5s) no idea which on mine only updated the once, is it worth upgrading??? or is it a case of if it aint broke???Updated my F5s with the V5s firmware this morning. Used AJ's (Ireland???) channel list. Still not up to date. It's downloading the 12/9/15 list.
It does save a bit of time this way, but if they can't update their database with the latest lists quickly, then it's not much use if your missing your favourite channel due to a frequency change.Comment
I suppose it depends on how inconvenient updating the channel list is for you using a USB memory stick. Just checked again today & the latest channel lists are still not there yet! Can't understand why they are not up to date?
Also, if your firmware is very old, it may not have the XMLTV fix which, after the clocks change soon, will hopefully not have the 1 hour difference any more.
You can check your firmware by looking at the software ver. in menu > tools > information.Comment
Thanks bud will check...I am still doing the worrying about the flash screwing the box up. I am sure its ok though but would love to know what i would gain in doing so???I suppose it depends on how inconvenient updating the channel list is for you using a USB memory stick. Just checked again today & the latest channel lists are still not there yet! Can't understand why they are not up to date?
No
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
Just installed the UK channel list & it's not CWAITE's list this time. It starts on ch1 (so not sky numbered) & it's not AJ's. There are a lot of "no name" channels and number channels in the list, like you get when you do your own scan, so don't know where it has come from.
EDIT...just found that channel 599 says that it's AJ's list 12/9/15. So it looks like it's the AJ 12/9/15 list that has just been blind scanned.Last edited by Hadron; 13 October, 2015, 18:25.Comment
