How to get channels back?
  • scotlandw123
    • Apr 2015
    • 23
    Most/all of my channels are starting to go on aj's list?
    tried updating it as well?
  • martin035
    • Apr 2014
    • 1308
    Try cwaites' list and see if that makes a difference;
    The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
    • scotlandw123
      • Apr 2015
      • 23
      nope not working, do i need new software update or anything?
      • martin035
        • Apr 2014
        • 1308
        Have you unrar'd/unzip'd the channel list first as the downloaded file comes compressed, you then should have a TP_PROG.dbs file which you place on the root of your USB drive, as cwaite's list defiantly works.
        • scotlandw123
          • Apr 2015
          • 23
          yes all channels not working, was ok on sunday
          • Hadron
            • 2102
            I replied in AJ's thread before seeing this one.
            Do you still receive the FTA channels, or are ALL of your channels not working (your first post says "most/all")?
            What message do you get on-screen?
            • martin035
              • Apr 2014
              • 1308
              I've just seen your reply on the other thread too, as your free to air are working and it's the $ channels, there's nothing wrong with your setup, something that we can't discuss due to the forum rules has expired.
