Recording to a Sata HDD
  • awt41
    • May 2015
    • 11
    I can record to a usb memory stick on my V8s with no problems, but when I connect a Sata drive several items in the menus are greyed out - everything relating to USB in the Tools menu + PVR and Media Player in the Multimedia menu.
    I've tried two Sata drives, a 2.5 and a 3.5 with it's own PSU - they both give the same effect. Unplug them and the settings re-appear.
    Any advice would be appreciated.
  • P&D
    • 2686
    What are the drives formatted to NTFS or FAT32
    • Hadron
      • 2102
      Do they work OK when you plug them into your pc/laptop?
      • awt41
        • May 2015
        • 11
        Originally posted by P&D
        What are the drives formatted to NTFS or FAT21
        Thanks for your replies.
        Both these drives work fine on my Windows 7 laptop. They are both formatted for NTFS.
        I had considered trying FAT32, but isn't that limited to 32gb?
          Fat32 is limited to 4GB chunks
          • P&D
            • 2686
            Hi it defo sounds like a conflict maybe a driver issue........
            • awt41
              • May 2015
              • 11
              Thanks, well my Software version is 3511HD_07_12_2014 so perhaps I should update that.
              However, I don't want to risk bricking it as everything else is working fine and I can live with recording to a memory stick.
              So - I think I'll leave things as they are for the time being, having learned t he hard way" if it works don't fix it" after years of always wanting that bit more!
              • P&D
                • 2686
                All i can say which is good advice.......Upgrade the box to an E2 system & then you will have some fun & many new doors will open
                • awt41
                  • May 2015
                  • 11
                  Which E2 box would you recommend?
                  • genam
                    • Apr 2013
                    • 176
                    Any thats have half decent user and seller support for images...images are like customised user interfaces..some are better than others.
