OpenBOX V8S Web TV Help
  • Cynderyn56
    • Dec 2012
    • 4
    Hi All
    Having trouble getting WEBTV to work on a V8S OpenBox
    I open the WEBTV APP
    I try any of the already installed England entries and I get
    An initial screen telling me connecting (0K baud rate) and then exists to blank screen
    I source and rename another list file so that the V8S can see it
    I install list file and it displays it correctly I try any of the entries and get
    The box is connected to the internet direct to my router which has a steady 40M fibre connection
    I have tested this connection by running the weather APP on the V8S and it works as expected
    Has anyone got WEBTV working on their OpenBox V8S
    Regards
    Cynderyn
  • dbroms
    • Jun 2015
    • 4
    hi mate , I have managed to use the WEBTV app fine , Its all to do the with M3U list you download and how valid it is. I downloaded an adult one which , for test purposes , I can post to you to try. All I do is put M3U file on usb , go to WEBTV , yellow button ( read by USB ) .Theres a list of 1107 ~~~~ clips , press the up button which takes you to bottom of list,select any file and press select. bottom rhs of screen you will a number Kb/s if this goes up it will work fine , if it stays at 0 its a dead link . If it plays this test list fine your setup works you just need a decent M3U list , if you google theres plenty out there .
