bigbhoy77, it's a zgemma skin available from the plugin section of the menu or via custom download, It however, will not work on an Openbox
Next box to go for
Which is the most up to date openATV firmware to use martin? theres quite a few on there site but im thinking the highest numbered is the most recent to use??
Also, can we use the dcc (one used on dm800se) software to correspond with the zgemma box or does it have to be a certain version to use with the zgemma H1 ?Comment
Gonna give that filezilla a bash this time as I used dcc for the dm800 so may as well try the other instead!
Actually forgot when I seen the openatv firmwares that its in a date ordered fashion, oops!!...... managed to get the correct file now will be putting that on but how about the channelling system and how that works? I understand that there's an autobouquets area in the menu but how do we get the channels in order or how we want them? bit like when AJ does his lists on here?
Thanks for the advice by the ways guys!!!
Remember to connect with filezilla you need the IP address of your Zgemma (menu-information-network) and username is root leave the password and port blank and press quick connect, left side is your PC right side your Zgemma, drag and drop.
You use autobouquetsmaker which is a plugin app, it puts the channels in $ky like order, but can be manually changed to suit the user, it auto updates the frequency of channels so no channel list once setup, some channels have to be added manually ie setanta hd, AMCfrombtHD and eurosportHD explained in the guide.
Menu-plugins Green button to add find Systemplugin- 'Autobouquetsmaker' and install
Then follow this guide to configure ABM http://www.digital-kaos.co.uk/forums...=1#post2593802 start@AutoBuoquetsMaker ie auto channel finder and favs maker
Hi martin!
Got my zgemma H1 box today, reflashed it with the most recent openatv firmware and followed your instructions, installed the autobouquets maker, followed the instructions to allow us to scan, did the tuner configuration to simple, now scanned but when I go back into the ABM to start a scan it doesn't pick nothing up but tells me there is a timeout for tuner lock??
Any ideas?Comment
1. First ensure satellite and cable feeds connected to box.Hi martin!
Any ideas?
2. Setup Tuner A - Config mode scroll to 'Advanced' , Satellite scroll to '28'2e Astra' ,LNB scroll to 'LNB 1' leave all other options default, Press Ok
3. Setup Tuner B - setup for cable ie network ID, qam and symbol rate.
4. ABM set up for satellite ie Granada custom
5. ABM set up for cable ie network id
6. Do your scan
