Is there a fix to correct the XMLTV EPG, since the clocks went back it's been 1 hour out, I've tried turning the summertime option to off but it makes no difference
Openbox V8S
Still working fine on my V6 (uses same firmware as V8).
Also the EPG on my V5s now works again (until next April that is!).
What firmware are you running? Don't know if it makes a difference, but both my boxes are using the latest firmware with the "update by Network" enabled.
