What could be the problem?
  • mikem93
    • Nov 2015
    • 5
    Hi everyone
    I have an openbox v8s, when plugged in no horizontal channels work. I did buy the fix for his from Amazon which never worked. Everything is up to date and the box works at my friends house. Stuck to what could be the problem. Any help would be much appreciated.
    P.S My TalkTalk box gets signal to all channels without a problem using the same cable directly from the LNB.
    CONFUSED
  • mezzyg
    • Apr 2010
    • 158
    Most likely your lnb needs changing if the box is working fine at your friends
    Sent from my SM-N9005 using Tapatalk
    • mikem93
      • Nov 2015
      • 5
      That's what I was thinking but then the TalkTalk box works and finds all channels. That wouldn't be the case if it wasn't working would it? Been trying everything I can think of.
      • Hadron
        • 2102
        Which TalkTalk box is that?
        I didn't know that TalkTalk made a satellite box.
        • mezzyg
          • Apr 2010
          • 158
          Talk talk box works through aerial and Internet. Not through dish.
          • Hadron
            • 2102
            Yep. Exactly. I use one myself. That's why I'm confused.
            mikem93 says that he gets all channels when connecting his TalkTalk box to the LNB cable ???
            • mezzyg
              • Apr 2010
              • 158
              He would as the box would still be using the Internet to stream channels connecting the dish wire is irrelevant
              • Hadron
                • 2102
                Only the premium channels are streamed. The freeview channels are received over the air.
                • mikem93
                  • Nov 2015
                  • 5
                  Oh I didn't know that. I've also connected a sky box too would this work just from the internet. If everything else is fine with the box and it works at my friends house is the problem definitely with the LNB? It is a new LNB so could it be due to the satellite dish in the wrong place?
                  • Hadron
                    • 2102
                    I take it you mean a BskyB sky box? Does that box receive horizontal channels?
                    • mikem93
                      • Nov 2015
                      • 5
                      I'm not really sure as I don't have a subscription with Sky so could only check on the freeview channels again. Oh and btw, the openbox did work when I first got it then I swapped it to my other living room and never worked since in either room.
                        Please do not connect the official TalkTalk receiver back onto the satellite dish connection as you will do more harm than good, as specified this receiver only needs a Tv Aerial connection and an Ethernet connection for the extra premium channels.
                        Any satellite receiver connected to your satellite feed will display the FTA channels such as BBC1,ITV,CH4 etc if it does nt then you have a problem either with alignment or again as specified above an LNB fault
                        • Hadron
                          • 2102
                          Try the Horror Channel on both your boxes. It's FTA & on a horizontal transponder (11265H).
