Skybox F5 firmware - Help
  • az007
    • Aug 2013
    • 51
    my box is stuck on the 'load' and doesent move any further. I have recovered the box with the Serial cable and loaded a previous backup.abs file.
    now im trying to upgrade the firmware on the box, i downlaldoed this image from here http://www.skybox.cc/down.asp?id=9
    when flashing , it says file mismatch.. so not sure if this is the correct image.
    How do i exactly know what box i have to flash the correct firmware on ?
  • Hadron
    • 2102
    Looks like you have a clone box.
    Unfortunately, the website that used to supply the clone firmware http://hddvbsw.com/ went down ages ago.
    What is the software date on your current firmware? If it's 26/03/14 then I think that was the latest. If not, try the firmware that I posted in this thread:-
    Hi there, does anyone have the skybox f5 clone image as the website i usually get it from is down. the websie i usually get it from is: http://hddvbsw.com/index.php?c=key_download thanks.
    • az007
      • Aug 2013
      • 51
      http://www.digital-kaos.co.uk/forums...ONE-IMAGE-HELP
      firmware i have is from 2012... what exactly is a clone box.. it all works fine etc no issues ive had. apart from after loading CWAITE Channel list 01/11/15 , it got stuck on load when rebooting so restored to backup image. never had issues with his channels lists. now flashed on 4/11/15, all goo now..
      Tried the image you recommended , still no luck, using serial cable flashed it, but then it starts loading from 0-99 and so on 0-99 constaly reloads... Just stuck my
      original backup image i had.
      • Hadron
        • 2102
        Usually a file mismatch error occurs when you try to flash an original box with clone firmware, or a clone box with original firmware, so it's odd that your box won't work with either firmware.
        I think the clone boxes were produced by another Chinese company to try & undercut the original manufacturer. The firmware wasn't compatible though, so they had to tweak the original firmware to make it work.
        I don't know what the later firmware revisions actually did. Some of them were issued just to try & get youtube & youp0rn working again, but it didn't usually last long.
        I have found another clone firmware dated 01/05/2013. It definately worked on my old clone F3 (which uses the same firmware as the F5). I have attached it if you want to give it a try. If it gives a file mismatch when updating by USB, don't bother trying to update by RS232 as it still won't work.
        • az007
          • Aug 2013
          • 51
          Great, this one flashed succesfully via usb.. all good now
          • mezzyg
            • Apr 2010
            • 158
            Different for both f3 older model
            Sent from my Nexus 6P using Tapatalk
