Skybox F3S - loads up to L100 and rebooted - flashed different firmware still same
  • jfish
    • 799
    As per title
    Got a SkyBox F3S where it loads up to L100 and then starst again so in a boot loop
    I have used a standard null modem cable and managed to flash various firmwares but none work and still get same problem
    is the box destined for the dustbin
  • P&D
    • 2686
    Hi have you tried this one dated the 8/9/15 .......Here
    • jfish
      • 799
      tried that firmware same result
      • P&D
        • 2686
        Are you ticking boot loader when you load the firmware ?
        into the flasher
        • jfish
          • 799
          into the flasher
          yes ticked boot loader
          how can I tell if the box is a clone or genuine
          • anom2
            • Apr 2015
            take a look at your sat cable going into the box I had that once restarting after 100 turns out it was the braiding shorting out on the connector rescrewed it back on and its still working now
            • P&D
              • 2686
              if you try to load the file i put in the link above.....Genuine box..........If you had a clone it would say file mismatch.
              Sounds like a dead box buddy.......Just before you bin it........
              I have to ask ...........when you have loaded the firmware & ticked the bootloader......then click next
              It loads the file ready for flashing..........Please tell me you burnt the file to the box ...takes 10 mins to do...
              I have known peeps load the firmware into the software.......I.e STB .......DONE & think this is it,box flashed
              Don't think so in this case but as i say had to ask
              Correct but i don't think this will be the fix for this box
              • jfish
                • 799
                at moment the box is not plugged into anything as in TV nor any satellite feed into box
                • Hadron
                  • 2102
                  If you have a spare Power supply from something else that uses the same connector @ 12v, with at least a 2A rating & with a +ve centre pin, you could try that.
                  These PSU's sometimes start playing up before they fail completely.
                  • charley
                    Hi jfish wer you able to get you f3s sorted if not I have repaired three of these boxes and it was caused by leaking caps on power supply board
