OpenBox V8S ! Problems getting signals
  • sonuwd
    • Jul 2013
    • 13
    Hi chaps,
    Bought an OpenBox thinking it will be OPEN
    Anyhow , When I start it up there were some channels list already presented and I try to watch it but nothing. NO Signals.
    Follow the instruction from the forum and install the latest software, upgrade it o~~~~~/by network too. Then install the latest channels list. Nothing. No freeview let alone OPEN channels.
    At the moment:
    Signals Intensity : 36%
    Signal Quality: 10%
    I have the original SKY+ box which has two cables connected to it on the back, I tried both of those cables one by one. same result in signal strength and intensity. But if I connect even one of the cable to SKY+ box it work fine.
    any suggestion please?
    Software: 10-09-2015
  • hongkongfooi
    • Aug 2015
    • 19
    did you turn the sky+ box off
    • P&D
      • 2686
      Hi check your settings
      antenna menu settings
      satellite 1/1 sky uk 28a
      lnb freq universal 9750-10600
      If all correct.....delete the channel list on the box & reboot it
      if done right you should have NoCH on the front display
      Down load this channel list then Load this via usb ....AJ's List 1-11-15.zip
      reboot the box see if you get the FTA back
      Make sure there is only one cable into the box from the dish.....Not in the loop
      make sure there are no cables from the dish in the original box this will interfere with the signal to the openbox
      Latest firmware is V8S_3511HD_CMT
      • sonuwd
        • Jul 2013
        • 13
        Antenna Setup Same AS:
        Software Ver: 3511HD-10-08-2015-06B7
        Channel list, the one you send me.
        Still the same thing. NO Signal.
        • sonuwd
          • Jul 2013
          • 13
          I have tried almost everything possible. I thing receiver on this box is faulty. It has no signal since I got it. So probably its faulty.
          thanks anyway.
          • sonuwd
            • Jul 2013
            • 13
            Any trustable seller to buy this box from? Who can at least check it before sending out faulty box.
