Changing ISP
  • molex1
    • Nov 2015
    Changing ISP
    I recently changed from sky to virgin media as my ISP. I have set up my openbox but cannot receive any signal for any channel. Please help!!
  • Hadron
    • 2102
    If you get "no signal" on all channels, then it won't have anything to do with your internet connection.
    • molex1
      • Nov 2015
      Thanks Hadron.
      What do you suggest that I try?
      • mezzyg
        • Apr 2010
        • 158
        Did you remove the dish wire?
        Sent from my Nexus 6P using Tapatalk
        • Hadron
          • 2102
          Make sure the LNB cable is in the LNB socket & not LOOP.
          Make sure LNB power is set to ON in Menu > installation > LNB power.
          Do you have any other sat receivers that you can test your feed on?
