skybox v8s
  • gc sat
    • Feb 2012
    • 9
    skybox v8s
    need help please its driving me mad for the last 2 hours im setting up box put in my ...... is on line is connect now put in ajs channel list when i go to fav no channels work only free channels if i do a blind scan all channels work but only in all satellite not in fav any help would be great thanks gc sat
  • P&D
    • 2686
    delete the channel list....reboot the box
    load Aj's list
    Box off router off
    wait then switch both back on......should sort the problem if you not getting the $ channels
    • gc sat
      • Feb 2012
      • 9
      thanks done all that still no joy
      • martin035
        • Apr 2014
        • 1308
        Do what P&D describes again but this time use Cwaites channel list.
        The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
        • gc sat
          • Feb 2012
          • 9
          no mate tried that still the same i have been setting up boxes for 20 years never came across this must be fault in skybox v8s
          • mikeywithanr
            • Mar 2014
            • 19
            I had same issue but with the f5s , I updated firmware and it solved the issue .Maybe try the same with V8s ?
