2 Openboxes Glitching Octo LNB?
  • ashmo
    • Sep 2013
    • 10
    I've just installed 2 openboxes onto my octo LNB (currently already had 2 sky+ HD boxes connected) and both openboxes randomly freeze on channels, its not the Forum Rules as I use the same provider at another address and its spot on 247, SNR is 54% on movies, 84% on BBC, could it be the LNB as I've read somewhere that some octo LNB's casue issues?
  • digicon
    • 8261
    Cant help with your so called provider part due to Forum Rules, but there are enough posts on the forum if you search detailing the problems with these cheap receivers and problems using them on the same LNB as official receivers
    • joe516
      • 1000
      54% will cause glitching
      information given is to be used for educational purposes only
      Don't Forget To Say Thanks If You Like My Post
      IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
      If It Ain't Broke Don't Fix It
      • P&D
        • May 2010
        • 2686
        Disconnect the official boxes & then the cheap boxes will run fine
          Run fine
          • P&D
            • May 2010
            • 2686
            Can't believe i said that buddy......I think I must have Alzheimer's...But now most sellers are throwing in a FREE bundle package with the box.....Don't get excited......It's for safety reasons....
