FTA HD channels say no signal
  • Davejus
    • May 2015
    • 9
    Hi
    Ive set up a new openbox at a relatives and done the usual things but the free to air HD channels (and non FTA HD channels) show no signal. Anything in sd works no problem. Used Ajs latest list, same one as I use on my box. Could it be a dish problem? the f connectors look a bit ropey but I thought if it can pick up all of the other channels the connection would be ok. Any thoughts?
  • gary229
    • 265
    are the settings on the box set to hd 1080
    • Davejus
      • May 2015
      • 9
      I'm at home now but Ill check in the morning mate. I assumed they would be as I haven't had to alter the other couple I set up. basically just plug and play......or so I thought
      • gary229
        • 265
        Normally are, is it just fta or does bt sports clear in HD? there is also the possibility that a simple change of hdmi cable may be required.
        • Davejus
          • May 2015
          • 9
          No, BT HD or AMC HD same story. Ill try another HDMI as well
          Much appreciated
            Try a different channel list ??
            • gary229
              • 265
              Its very rare to have no hd channels at all not working on the box. I'm not aware of any channels changing of late, hope its the hdmi, nice and simple fix!
              • P&D
                • 2686
                You don't say what box.....there are a few
                What firmware do you have on the box.....does sound like a dish problem or tuner problem if it's a new box
                can you take the box to yours & try it....If it works then you know the problem cables
                The dish
                • gary229
                  • 265
                  At the very least even with a dish slightly off you should pick up FTA HD, now as its a brand new box, I'm assuming it's a v8s. This being the case when you set the box up I'm hoping the sat feed went in first. If the box has been powered up and the sat feed added last there has been issues with hdmi ports blown this way.
                  As stated before I would change the hdmi cable and check your box settings.
                  if still no good I would contact the seller and exchange the box, if all above has no success
                  • Davejus
                    • May 2015
                    • 9
                    I have tried a different HDMI but it made no difference , brought the box to my house and everything works fine. All channels are on. So.. its the dish or the cable connection?? unless anyone has any other thoughts
                    It is an openbox V8s by the way
                    • gary229
                      • 265
                      So is the settings on the other tv you used it on set to 1080i, if the box works fine at yours the hdmi port is fine.
                      Or maybe you'll need to check his cabling, but with all sd channels working your getting a signal.
                      • Davejus
                        • May 2015
                        • 9
                        checked (and replaced) f connectors but the problem remains, noticed its not just the HD channels giving the 'No Signal' message- its itv 2 bbc3 etc also sd bt channels. Going to get the dish alignment checked but I'm still convinced I'm missing something. signal strength on sports/movies is in the 80 to 90% ranges, snr is high 70s. on the HD channels snr is 10% and signal strength is 0
                        • gary229
                          • 265
                          long shot here try uploading cwaites channel list via usb from above and see how that goes
                            Said that a while ago
                            • Davejus
                              • May 2015
                              • 9
                              ill try it tomorrow. I thought the fta channels would work without any updated channel lists, but at this point I game for any alternatives.
                              cant understand how they would all work with my dish setup though
