F3S sudden no signal problem
  • middots3
    • 194
    Hi all i have a V8S in my living room, a F3S in my bedroom and another F3S in a different bedroom.
    The F3S in my room has all of a sudden started showing up "NO SIGNAL" on ALL channels. I haven't updated or anything.
    I noticed this last night, then it suddenly went off and was working as normal all night, until i just turned it back on and "NO SIGNAL" again???
    Both other boxes are working fine so it can't be a dish alignment problem. I'm a bit stumped? I haven't done any updates as of late and it has just happened completely out the blue.
    Any ideas?
  • P&D
    • 2686
    Sounds like a new LNB could be needed
    disconnect the feeds from the other 2 boxes that are working (sat cables)
    then reboot the box thats not working to see if you get the channels back
    Have you got a feed (cable) to each box or are you using a spilter ?
    • middots3
      • 194
      I have a double LNB.
      The box downstairs has the usual 2 cables going into the back of the V8S.
      The double wires upstairs both go into my bedroom but i have split them and one veers off into another bedroom.
      One going into the box that is showing no signal:
      And 1 of the double wire going off into another room:
      Do you think this method is causing problems? It's been working fine for about 6 months.
      I've tried using other boxes with the wire in my room and still nothing. It will come on intermittently for a while then just go of again.
      • P&D
        • 2686
        The box down stairs only needs one cable.......
        Have you tried what i said above ?
        • middots3
          • 194
          Yes i have tried it, no luck.
          It is all working fine again now though, maybe the rain the other night disrupted the signal? I'm stumped .
